torque arm ?
Old Dec 30, 2014 | 06:24 AM
fastazzls1's Avatar
Default torque arm ?
ok I removed torque arm to change mount and clean it up since my oil leak caused last mount to fail. Fixed oil leak as well lol the rear diff and the torque arm both shifted upward towards the floor pan my ? is do I need to recheck my pinion angle after I reinstall the torque arm
Old Dec 30, 2014 | 07:51 AM
Heat Seeker WS6's Avatar
I wouldn't think so if its an OEM torque arm.
Old Dec 30, 2014 | 08:36 AM
UMI Performance's Avatar
If it is a factory torque arm than no, no way to adjust it. If it is adjustable and you didn't change the torque arm than it should be fine as well.
Old Dec 30, 2014 | 08:38 AM
SCott5's Avatar
This^^
