Torque arm geometry help
I'm using a UMI torque arm seen in the picture below. With the car sitting at ride height, is it ideal to have the top bar of the torque arm horizontal to the ground? The front mount point will have adjustable height, so I'm trying to determine if the lowest setting should be level with the ground, then have adjustability upward, or am I thinking about this the wrong way?
Any help is greatly appreciated.
http://www.pro-touring.com/threads/8...-Nice-rear-end!
http://www.baselinesuspensions.com/i...A_Drag_Car.htm
Should the lowest mounting point of the poly mount be level with the ground, and have adjustability upward?
