Better than stock replacement for 2000 TA?
Hey guys, so I need to replace my shocks/springs for my 2000 Trans-Am. Right now I have about 150k miles and factory shocks/springs. The suspension badly needs replacing, and I thought I might as well upgrade while I'm at it. I'm looking at:
http://www.slponline.com/product/700...on-System.html
Will this suspension package be OK for daily driving? Is it comparable to 1LE so far as handling, or should I buy that from GM directly? It does NOT lower the car, correct? Thanks!
Sorry, I guess I should add that it's a 2000 Transam, auto, pretty much full bolt-ons, SFCs, and it's my daily driver, though I do take it to the track occasionally. Thanks again!
Thanks for the reply!
Stock springs don't get "worn out" like shocks? Also, what shocks would you recommend, and where's the best place to get them? Thanks again!
If you want a good replacement look into some bilstiens like those and keep the stock springs like already stated. If the springs are not sagging then they are likely fine.
Also worn out shocks work pretty well for drag racing if thats what you care about.
Either of these would be a good choice for budget:
http://www.stranoparts.com/partdetai...D=21&ModelID=8
Pontiacerator
I would only replace them if:
1. They are sagging significantly
2. You want to lower the car more than .75"
3. You want a stiffer spring for handling purposes
