Shock Swap
also now would be a good time to check your tie rods if they are getting anywhere near worn out now is when it makes sense to replace them since you will need an alignment after installing springs/shocks.
As far as the MWC Watts link setup there should be no issues caused from any spring,shock, or mounts you use.
Moog all around: Front Shock Mounts, Upper and Lower isolators, sway bar end links and tie rods. Might as well right?
Any other suggestions, since Ill be in there?
