11 inch rears with stock height and bump stops?
Is this possible? My car is lowered right now, with no bump stops but I was wondering if stock height was possible without removing the bump stop bracket/assembly piece.
Currently no bump stops.
It is. I have 17x11 TT-2s at stock ride height with bumpstops. Even lowered you do not need to cut the bumpstops out. BFH the inner wheel well and rolled fender lips may be required depending on the car.
You can run bump stops with wide wheels, you just can't jack the car up and let the rear axle hang unless you pull the wheels off. The only time the wheels contact the bump stops is at full droop. It blows my mind that so many people remove an important part of the rear suspension, especially when lowered.
