Rpo fe2
Old Feb 27, 2015 | 06:41 PM
98Zeric's Avatar
Default Rpo fe2
i tried to do some searching but haven't came up with any solid info. i have a 98 Z28 (Sep. 29 1997 build date). with rpo fe2 " Suspension system, Ride handling ".
other threads I've read claim the use of a different Rack & pinion as well of claims of the motor being located back farther ?
also read a spring rating of 548lbs (front), 131lbs (rear)?
all of this might not amount to really anything I'm just curious to know.. also when i need to replace the RP it would be nice to know what to get..if it even matters
the cars front coils have a part# 22077195 FZL
the struts are J4 3625"?"0
thanks for any help!
Old Feb 27, 2015 | 08:02 PM
SlasherVRGR's Avatar
FE2 is the quick ratio steering isn't it?
Old Feb 27, 2015 | 08:14 PM
98Zeric's Avatar
from what i seen the fe2 was 14:1 where the F41 is 12:1.. i don't know if that's for 3rd gen or 4th.. or if that matters.
do all of the 98+ have the FE2 option standard?
By Brett Foote | 2026-06-04 05:00:17
