Lower rear shock mount
Just received my new Koni Str.t and they appear to just have a nut and bolt to mount to the rear end. The stock shock bolt seems to have a spacer to shim the shock away form the rear end mount. Do in need a similar spacer or do they just bolt up without?
I have QA1's on my car and they use a nut & bolt also. I put in a couple of 1/2" washers between the shock and the mount so the shock wouldn't rub. You don't need much clearance, about 1/8" should be sufficient.
