Viking install. Which way is correct?
Old Apr 28, 2015 | 09:59 AM
jaybob's Avatar
Default Viking install. Which way is correct?
Which of these is the right way to assemble?
Old Apr 28, 2015 | 10:01 AM
UMI Sales's Avatar
Links aren't working but I'd be glad to assist you when get some pictures up!
Old Apr 28, 2015 | 10:09 AM
jaybob's Avatar
Pic fixed.
Old Apr 28, 2015 | 10:19 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
The way on the right. That is a flat coil design on the end so you need the retainer cap. The only way to do that with the factory spring seat are the special springs that Qa1 makes.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Apr 28, 2015 | 10:26 AM
jaybob's Avatar
Thank you! I assumed that was the correct way, but I was afraid of the stress on that little stud.
Old Apr 28, 2015 | 10:47 AM
BMR Tech2's Avatar
I have no problem providing tech help to those who need it, even if they don't have our components. Just glad to be able to help. I run Vikings on my personal car so I definitely like to support their products. Let me know if I can help with anything else!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old Apr 28, 2015 | 10:49 AM
ssvert99's Avatar
Theoretically the method on the left side would work, but not necessarily the right way to do it. The Viking shock setup you have is designed to use the upper spring cup in conjunction with the 2.5" ID coil-over type spring that comes with the package.
There is another method to mount the upper, but it uses a spherical bearing and custom mount for the body instead of the stud and factory rubber mount. The coil spring in this application is still mounted with the supplied cup from Viking similar to the stud type mounting.
Old Apr 28, 2015 | 10:57 AM
jaybob's Avatar
I just wanted to make sure. I was prepared to buy different springs to make it right if I had to. Like I said, It just seems like a lot of stress on the stud and the center of the mount. I've considered converting to bearing mount. If I have any issues, I will.
Thanks again everyone.
Old Apr 28, 2015 | 11:07 AM
ssvert99's Avatar
The stud will work fine and has been proven to be durable as well. There are by far more stud upper mount aftermarket shocks out there than the bearing type, but there is no doubt the bearing upper will never have any issues with strength or bind through the suspension travel.
