Subframe connectors welding points
If the "connector" is designed that way it is NOT a true subframe connector, maybe more of a "jacking rail" that protects the pinch welds on the rocker and not doing much of anything for chassis rigidity.
To answer your question simply, yes. You bolt them up to locate them, then weld them.
