Suspension to prevent issues
The car has T tops and SLP subframe connectors three point. The car is lowered, but I am not sure on what brand of springs. It appears to be lowered about an inch.
Currently the car feels very stable and tight, unlike my previous lt1.
I have done extensive reading on this forum and tried to learn about LCAs and shocks and springs.
My question is what additional suspension modifications would you recommend if any?
My goal is for a smooth ride and to prevent future rattles.
Thanks
You've already got the 3 points, just make sure they are welded in.
You can have the stiffest chassis in the world but with shitty shocks the car will feel sloppy and case rattles.
Get some good shocks, SLP bilstiens, Koni STR.t, Koni sport SA's.
Forget LCA's and just about anything else, nothing will make a bigger difference. Get good shocks first, worry about the other little stuff later (if at all).
Also sound deadening material wouldn't hurt either.
Other than stiffing up your chassis you could apply sound deadening, if you have the patience to tear out the interior and apply deadener piece by piece
