rear brake question
Went to do the rears today and when I went to undo the bolt that holds the caliper to the bracket it just turned (the upper one). According to my FSM the upper bolt should have released the caliper (just like the fronts). After throwing my hands up, I put the wheels back on.
Later on I was thinking could a previous owner somehow switched the brackets and calipers side to side and the bolt I needed was the lower one instead? Or is my FSM wrong and its the lower bolt I needed to remove?
