Help which koni shocks
Old Dec 28, 2014 | 07:08 PM
josh4ku's Avatar
Default Help which koni shocks
I am going to replace front and rear shocks. I would like to go with koni single adjustable. Everyone here seems to think they are the best shocks available. I am looking for a good ride quality, but need to adjust to perform well at the track also. I'm going to use stock springs, I don't want the car lowered. I see there is a sport yellow shock? And some others . Which ones do I need?
Old Dec 28, 2014 | 07:16 PM
Daniel Richards's Avatar
the yellow SPORT shocks come in multiple variations. starting with (off-car) single adjustable and going up to double adjustable, so the "cheap" set of Koni Yellows is the single adjustable set you are looking for.
Old Dec 28, 2014 | 07:23 PM
josh4ku's Avatar
So by "off car" meaning they can only be adjusted off the car?
These are what im looking at:
http://www.ws6project.com/user_stor/...s-single-adj-/
I just don't see why the need to spend so much more on double adjustable.
Old Dec 28, 2014 | 08:54 PM
josh4ku's Avatar
Also are stock springs ok to run on koni shocks?
Old Dec 28, 2014 | 09:03 PM
79_T/A's Avatar
Absolutely. Koni yellows also have 2 spring perch locations for the front shock. The upper is stock height, the lower gives a very slight drop on stock springs. Car will feel much better with Koni shocks on the stock springs. Much better ride quality.
Old Dec 28, 2014 | 09:09 PM
josh4ku's Avatar
Good to hear, Excited to try them out! thanks
Old Dec 28, 2014 | 09:13 PM
josh4ku's Avatar
my MWC fab 9 has transverse shock mount brackets. Which is not what the koni shocks come with. Is that available for the koni? I think it would need to be converted to a bushing or bearing mount.
Old Dec 28, 2014 | 09:38 PM
MrEddie's Avatar
yup, the Koni single adjustable (rebound) are what I have. I ran them on the stock springs for about a year. To adjust the fronts, I had to slightly jack the front to expose the adjustment slot. Then you insert an allen wrench or a pick to move the adjustment left or right to either stiffen or soften the rebound. The rears are easy to install and adjust. The adjustment uses the Koni **** that you slide over the top and turn. Whoever does the install, make sure the adjustment slot is facing outside the car; otherwise, adjusting might be impossible if facing the otherway. I installed them myself, and when tightening the top nut on the fronts, the adjustment slot can rotate a little, so you might have to work at it a little. I got mine from Sam Strano, and he gave me some suggested beginning settings - worked great! Have fun!
Old Dec 28, 2014 | 09:40 PM
josh4ku's Avatar
Originally Posted by MrEddie
yup, the Koni single adjustable (rebound) are what I have. I ran them on the stock springs for about a year. To adjust the fronts, I had to slightly jack the front to expose the adjustment slot. Then you insert an allen wrench or some a pick to move the adjustment left or right to either stiffen or soften the rebound. Who ever does the install, make sure the adjustment slot is facing outside the car; otherwise, adjusting might be impossible if facing the otherway. I called Sam Strano and he gave me some suggested beginning settings - worked great! Have fun!
Ok thanks, I'll make sure the adjustment is facint out. Do you know if there is a lower rear bearing mount available for these?
Old Dec 29, 2014 | 02:42 PM
josh4ku's Avatar
Well i just put my order in at MWC for a full set of viking coil overs! They are getting to be more & more popular it sounds like.
Old May 18, 2015 | 08:13 AM
ramairetransam's Avatar
im leery of the viking as strano doesnt sell them , just curious as to why he doesnt.
Old May 18, 2015 | 08:16 AM
red_00z28's Avatar
maybe it's as simple as he is not a dealer for them.
Old May 18, 2015 | 10:07 AM
blackandgold's Avatar
Do some searching. Strano = handling. He will sell you viking shocks if that's what you're dead set on. Viking's are good for the strip, there are a few threads on this, but I'll be sticking with Koni's or maybe KW.
Old May 18, 2015 | 05:05 PM
M4N14C's Avatar
Koni = Handling
Viking = 1/4 Mile
Strano focuses on handling so I don't see why he would sell drag shocks.
