Advise on suspension setup
I moved the Lca to the lowest hole, and it would hit the tires really hard, carry the front tires 6-12" in the air for 20' then unload the rear suspension and spin the tire. Eric at MWC suggested I tightening up the front shocks a couple clicks, and moving the bar back up 1 hole. Get the LCA a bit more parallel with the ground so, so it didn't hit the tires so hard. Big improvement car stays closer to the ground and doesn't spin anymore.
post #3 here https://ls1tech.com/forums/suspensio...n-bracket.html
and post #5 here https://ls1tech.com/forums/suspensio...t-setting.html
but like other have said, try your most recent changes first and then decide if you need more.
I can't find it now but there was another thread that had graphics that explained it all real well. basically for the street you want the lower control arms level to slightly uphill from the rearend to the body so the weight of the car is pushing down on the rearend, because if it's the other way you lose traction and have wheel hop because the control arms are "pushing" up on the rear end, this is commonly experienced when you lower a car (if I keep the car much longer I desperately need to get a set of these to complete my setup), but you don't necessarily want to go to extreme with it on the street because it could affect your cornering, but straight line drag races don't need to corner and want the best launch so you go with the steeper angle. it's all a balancing act to find what works best for your exact setup.
