Newbie needs help
Old Jun 21, 2015 | 10:34 PM
ACNMNY's Avatar
Default Newbie needs help
I have a 98 Camaro with stock springs and shocks. I want to do a drop and some good shocks. Not sure if this matters but the car will see some drag strip time. Any suggestions?
Old Jun 21, 2015 | 10:43 PM
Daniel Richards's Avatar
https://ls1tech.com/forums/suspensio...ure-build.html post #4
Old Jun 22, 2015 | 03:28 PM
blackandgold's Avatar
Lots of threads out there. Basically you have a choice up front: do you want a drag setup that will be bomb at the track and be adequate for the street (as long as you aren't carving up corners) or do you want a really solid street setup that will be good in corners and give up some time at the strip?
