motor mounts
Old Aug 6, 2015 | 06:14 PM
KH504's Avatar
Default motor mounts
I'm getting ready to put my 418 in my car and I was thinking about changing the motor mounts. I will be running a fast 102 so I don't want to raise the motor up. What should I use, or do most people just run the factory ones?
Old Aug 6, 2015 | 09:21 PM
conan's Avatar
Go with some Prothane Poly motor motor mounts. I also like my poly transmission mount, the drive train is so much more stable. Some people complain of vibration from poly mounts but I haven't had any problems.
Old Aug 6, 2015 | 11:35 PM
blackandgold's Avatar
Do the spohn tubular mounts really raise the engine that much?
Old Aug 7, 2015 | 07:19 AM
UMI Sales's Avatar
If you want solid, we offer aluminum motor mounts machined from a solid block of aluminum that fit just like factory!
UMI #2323 Solid Aluminum Motor Mounts
Old Aug 7, 2015 | 08:32 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
From our own and several customers experiences there are a lot better options out there.
Old Aug 7, 2015 | 08:37 AM
ssvert99's Avatar
MWC offers high quality poly mounts from Prothane and Energy Suspension. This is the best way to get a firm mount without going full solid.
We also have solid mounts that are a direct replacement for the oem mounts that are very affordable at 95.00 http://midwestchassis.com/solid-motor-mounts.html
Old Aug 7, 2015 | 08:53 AM
UMI Sales's Avatar
Actually just yesterday I had a customer swapping his tubular mounts for our solid mounts if that speaks for the product.
Old Aug 7, 2015 | 09:58 AM
blackbyrd's Avatar
Have polys on both my cars. Actually have less vibration on the gto with the hinson poly mounts.
Old Aug 7, 2015 | 04:18 PM
That's fair, I always like the looks of the spohn ones and it looked like they added some clearance for headers, but I guess I'll go a different route when the time comes.
Old Aug 7, 2015 | 06:10 PM
dailydriver's Avatar
Do, or can your solid billet mounts cause any cracks/stress risers to the mounting points on the unibody in a daily street driven car, or is it just more NVH than the poly mounts??
Old Aug 7, 2015 | 10:04 PM
Thornton98's Avatar
I just installed the spohn tubular solid motor mounts on my f-body and I don't recommend them. Too much vibration at high rpms and when slowing letting the clutch out.
Old Aug 9, 2015 | 04:53 AM
Grifter's Avatar
So you installed a solid piece of metal to replace something rubber and didn't think they'd vibrate? You're going to get NVH regardless of what solid mount you use.
Old Aug 10, 2015 | 07:11 AM
UMI Sales's Avatar
I've never experienced this issue, or heard negative feedback in those regards. It is slightly more NVH than poly.
