Pinion angle ?
Old Sep 5, 2015 | 03:16 PM
kinglt-1's Avatar
looks like it is mounted too high...or is that what you cam up with after testing?
Old Sep 5, 2015 | 04:10 PM
Chris25's Avatar
Thats the third hole from the top everyting felt ok I havent really beat on it yet.
Old Sep 6, 2015 | 08:08 AM
2JAWZ's Avatar
Originally Posted by kinglt-1
Just a heads up, The car sat really high from the factory, but now has a nice stance after the BMR springs Here are some pics for comparison. So even after the spring swap I think it should still hook decent after some suspension tweaks.
She looks real good,, and I also like the silverfish wheels with the red* Now time for some tint**
Old Sep 8, 2015 | 11:59 AM
Chris25's Avatar
Default Pinion angle ?
Does anyone know if I should cut the tip of the TA a little bit so it doesn't stick out to far. Is this normal?
Old Sep 8, 2015 | 12:29 PM
Cpt.Derrek's Avatar
should be fine, there shouldn't be any reason you need to cut the end of it off, it needs to be able to move around a bit anyways. Unless its hitting something or your a hard core weight saver then I guess you could.
Old Sep 9, 2015 | 10:49 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
There is absolutely no reason to cut the end of the torque arm at all. It is supposed to stick out through the bushing because it will move back and forth through the bushings as the rear suspension moves through its range of motion.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Sep 9, 2015 | 01:40 PM
Chris25's Avatar
Awesome thank you. I was just making sure that's normal.
Old Sep 9, 2015 | 02:08 PM
BMR Sales2's Avatar
Not a problem at all, if you have nay questions don't hesitate to shoot me a PM or give me a call at the shop.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Oct 6, 2015 | 10:07 AM
kinglt-1's Avatar
Just a update...installed the BMR adjustable tq arm and relocation brackets. Started in 3rd hole from bottom, pinion angle -.5. Still had zero traction. moved up to the 5th hole and -2 degree pinion angle and the car is hooking much Better. Almost seems like I could go to the 6th hole but I am going to get new DR's first being my toyos are down into the wear bars. However I am very happy with the results so far.
To give a example: I went from not being able to go past half throttle in first gear to just slight needing to lift in first gear from a dig. First gear will now stick from a low roll instead of going straight to the limiter.
