Pinion angle ?
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
What is best for the OP might not be what is best for you but the stock location should be right around the 3rd or 4th hole from the bottom but since you are lowered also I would probably start in the 3rd hole too. . Since you have an adjustable torque arm you can take advantage of using any of the holes on the crossmember so make sure to play around with it and find out what your car really likes. The higher you mount the torque arm on the crossmember the harder it will hit the tires but it won't carry the power out as far. The lower you mount the torque arm on the crossmember the softer it will hit the tires but the further it will carry the power out.
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
There use to be serval from the Fort that posted hear but not so much anymore. I do not get out north much anymore on the weekends. Normally just cruise around out South West.
I'm from the northeast area, gonna be competing in the last few autox events of the summer at the Coliseum What is best for the OP might not be what is best for you but the stock location should be right around the 3rd or 4th hole from the bottom but since you are lowered also I would probably start in the 3rd hole too. . Since you have an adjustable torque arm you can take advantage of using any of the holes on the crossmember so make sure to play around with it and find out what your car really likes. The higher you mount the torque arm on the crossmember the harder it will hit the tires but it won't carry the power out as far. The lower you mount the torque arm on the crossmember the softer it will hit the tires but the further it will carry the power out.
Glenn ***
Sales Tech
813.986.9302
