New rear end?
I am at a point where I have not spent much on this particular repair and am weighing the merits of buying a 9 inch axle assembly instead. The car is road raced a lot, so the idea of dropping a little unsprung weight is appealing (aluminum center section, stamped or fabbed housing, etc).
If you've been through such a swap, how did it go for you? 4th gen fbody guys, did you have any isues getting your brakes to fit?
Vendors, what are your options or suggestions? If it matters any, the car has hyper coils composite rear leafs and a fays2 watts link.
Edit, just realized what I wrote doesn't completely apply to your 2nd gen regarding the 7.5 10 bolt.
The MWC fabricated rearend is a great choice for roadcourse and autocross cars as it will be among the lightest and strongest setups you can get. I would say an easy 30 pound reduction could be in store for this application.
Your leaf spring suspension and brakes will be a direct fit as well.
Give us a call and we will be happy to go over your needs and figure out a cost. I think you will be pleasantly surprised on how affordable it can be!
