wilwood rear brake kit
hey guys i was wondering if this brake kit will work for my 02 ss camaro? I just purchased a ford 9" for a street/ strip build im doing and I want to upgrade the brakes but I need to know what wheels will fit and wheels will not. I have these wheels on the car right now http://www.oewheelsllc.com/Wheels_3/...Wheels-Black_3
will these brakes clear
http://www.summitracing.com/parts/wi...t/model/camaro
thanks guys
thanks guys
Youll have no issue clearing that setup. However, whats your goal? Strange has a setup for about half that price, with what looks to be identical calipers but lighter rotors. I just installed a set on my car. Heres some info:
https://ls1tech.com/forums/multimedi...cs-vids-9.html
thanks man...my goal on brakes is getting something a little bigger but much better than stock and be happy with what I put on the car. I want it to function great but also look good as well. Now I just need to see if the wilwoods will fit up front. the company im buying the rear from stated they would give me a better price on the brakes so thats helping as well
Too much rear brake on these cars will cause axle hop under heavy braking. The road race guys usually run a stock like brake pad with good blank rotors in the rear, and a good blank front rotor with aggressive pads (upgraded calipers in the front to prevent spread the stock ones can have).
Those will certainly look cool, but they are waaaay overkill for road race and may even lead to lock up or wheel hop problems on the track. I personally wouldn't bother with anything larger than 4th gen LS1 stock rears. "Much better than stock" can easily be accomplished with pads and calipers only, but you'll likely only need pads for back. Fronts are where you need to focus *if* performance is the primary goal.
Now, if you're going for looks and want rotors that fill up the wheels, then yeah, by all means look at getting the bigger nicer looking brakes. I'd do some research first though, before picking something. If you look at my thread, you'll see what a 330mm slotted rotor looks like inside a 17" SS Wheel (C6 Z51 front brakes)
