Quick Front upper control arm question, Camaro.
Thanks for any help,
Rob
But yes, once they are torqued they are stiff.
New Parts
Upper Control Arms
Lower Control Arms
Sway Links
Tie Rod ends
Pre loaded Shocks mounts and springs
Thanks,
Rob
Rob
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
1) L R Lower Control arms Mevotech with New Bushings and Ball Joint.
2) L R Upper Control arms Mevotech with New Bushings and Ball Joint.
3) L R Outer Tie Rod Ends.
All bushings and Ball joints were severely worn. The lower control arm bushings were torn on the rears. I have not had car aligned yet but steering and brakes are much more solid after a drive around the block. No question about it, this all had to be done.
However the main reason i did this was a really bad clanking clunking while braking. And it is still doing the same thing.
My driveway has a slope to it. When I put the car in reverse and roll back and Brake im hearing a really loud Clanking noise. I say Clanking as it sounds like Metal on Metal. If I roll back and tap Brakes 10 times I will hear the noise evry time the brakes are actuated.
If I put car in gear (auto tran) move forward to about 5 MPH then tap the brakes repeatedly the I will hear the same noise.
If the car is moving ahead at 50 and I brake I dont hear it.
What the hell could this be?
Lemme Know if you have any thoughts on this.
Thanks,
Rob
I don't want to "rain on your parade", but my one thought is this....Mevotech??? I'm assuming you got these Mevotech parts from Rock Auto Parts. Look at the cost of the Mevoteh complete control arm, with bushings and ball joint already installed, compared to the cost of a Moog ball joint alone. There is a reason for this.
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
I understand your point, however, the critical part is the ball joint, and secondarily, the bushings. After I retired from full time work, I worked for a few years at my local Advance Auto Parts store. We sold Moog parts, as our "top shelf" parts, and we also have a much cheaper line, know as the "white box stuff"......parts that might last a year or so.
Therefore, as I initially mentioned, look at the price of just the Moog ball joint, and compare it to the cost of the entire Mevotech control arm. There's a reason.....
Have not had a chance to get it over on the lift yet. Do you think it could be the U-Joint?
Thanks,
Rob
On another note: how are the mevotech control arms working out? I've been contemplating getting them when I completely tear apart my front end.
