Abs/brake light
Old Oct 31, 2015 | 10:30 AM
Chris25's Avatar
Default Abs/brake light
I swtiched to 285 40 18's in the rear with 255 40 17's and my ABS/BRAKE LIGHT are stuck on. My tuner tried to switch the settings in HP tuners, my question is will this cause any issue at the track? Should I just delete my ABS.
Old Nov 3, 2015 | 08:27 PM
kinglt-1's Avatar
if there is more then 1" in height difference between front and rear tires then you will get the abs light....nothing can be done other then pull the abs fuse and deal with the light.
Old Nov 4, 2015 | 02:06 PM
Chris25's Avatar
Ya I guess I will just deal with the light until I get a set of racestars for it.
