Hitting bump stop?
About 8 months ago I installed a set of fleabay springs (I know... they were a gift so I put them on while i saved up for a better set. These ones specifically: http://www.ebay.com/itm/1-5-DROP-SUSPENSION-LOWERING-SPRINGS-SPRING-93-02-CHEVY-CAMARO-FIREBIRD-BLUE-/400493654995?fits=Year%3A2002%7CModel%3ACamaro&hash=item5d3f4833d3&vxp=mtr)
Spring rate for the rear is listed at 250lbs/in.
I jacked up the rear today to fix a rattle coming from the panhard bar, and I noticed that the passenger bump stop seems to have been contacting the axle.
Is this indicative of ****ty springs? Or is it a shock absorber issue? I'm still running the stock shocks (again, I know) and would be more than happy to replace them if necessary.
Take into consideration that your car is now over 10 years old and those foam bumpstops will be worn down. You can replace them with some oem ones, or poly jeep ones.
As for your springs and shocks, if you don't like the way the car rides, feels, handles, or behaves, well you know why.
Those spring rates are wacky (rear is way too stiff compared to front), makes me wonder who came up with them.
Also funnily enough, I already replaced the pass bump stop already. The first one was completely rotted away (disintegrated when I pulled it off) the one currently on there is an OEM one that seems to be holding up okay.
If I had the money for the poly ones, I'd get them lol.
If you want to be lowered there are a ton of better options on springs.
http://www.stranoparts.com/partdetai...=113&ModelID=7
the .5" raise over what I currently have I was hoping would help eliminate some scraping issues over speed bumps.
I think you'd find my springs better to be sure. But the fact you touching the bumpstops is not abnormal, in fact it's part of how this suspension works, and why I go nuts when people take them off (that's not smart and creates other issues).
Let's say those are 250 rear, give or take. That rate doesn't keep you off them anyway, so why run that stiff? The trick to springs is to make them as stiff as you need and not stiffer than you want. My springs have a very well proven track record. And I can tell you that for what the ones you have cost, that doesn't come close to getting one half of my set made (cause my stuff ain't cheap).
They claim a 1.5" drop. that's fine, but drops are not all the same due to a lot of variance in not only stock springs or whatever your starting point is, but also in cheap springs like this. I used to call mine 1.2", I don't call them anything like that anymore because some people freak out about .1" difference from that in terms of their drop (up or down) without regard to what the car has for options, what's inside (like a big speaker box), wear of the stock springs, cutting stock springs or even the fact the might not HAVE stock springs to start with.
There is no shortage of pics of cars on my springs. Google "strano springs" or you can even go here: https://ls1tech.com/forums/appearanc...ring-kits.html to get a sense of what you'll end up like.
I can't see your car so I can't say it'll come up, or how much. It might. Could even drop if their number is way off reality.
Now to the Hotchkis you linked. Clearly I sell them, you linked my site. But they are frankly overpriced and don't work as well. They aren't even really much different in height than mine. I'd be happy to supply them to you if you want but you can do better IMHO.
Sam, are the hard, high durometer, POLY 'Jeep' ones (that everyone on here seems to be SO fond of using as replacements) also a detriment to the way the suspension is supposed to work, as compared to the stock, GM/Dorman replacement 'spongy' ones??
They have about every manufactured bump stop that you would need
But, do the popular on here, poly ES Jeep replacement stops actually negatively effect the handling, or 'jounce rebound' (IF there is such a thing??) as compared to the stockers, or your rubber compound stops, especially in rough/washboard mid corner scenarios on the stops??
So much for those on here saying their hard poly Jeep bumpstops are "perfect" replacements.
And yes, "wheel rate" was the term I was thinking of when I said "jounce rebound" above.
They aren't perfect, and if you recall I don't say that. I say they work, and are better than nothing at all, but not perfect. The rubber ones are definitely better and more progressive.
