Camber Maxed out
Old Oct 31, 2015 | 04:20 PM
bhotrod3's Avatar
Default Camber Maxed out
I know this a not a new question but i,m not sure where to look for the answer,my camber is maxed out on my lowered 2002 T/A,what are the fixes for this problem,any help would be greatly appreciated,thanks ahead of time.
Old Oct 31, 2015 | 06:01 PM
Corvett z07's Avatar
........is it maxed out and still positive camber or are you just not getting the numbers that you want
Edit* - Just to make sure you know, maxing out your camber isn't necessarily a bad thing... It's not like maxing out your injectors or anything
Old Oct 31, 2015 | 08:42 PM
LilJayV10's Avatar
It will kill the inside of the tire w/ the quickness if it's really bad.
OP, adjustable lower control arms or elongating the factory holes will allow better camber.
Old Nov 1, 2015 | 07:32 AM
leadfoot4's Avatar
I agree. HOWEVER, maybe we should start by defining what you mean by the camber being "maxed out"......
Old Nov 1, 2015 | 09:32 AM
bhotrod3's Avatar
I still have negative camber,i am sure i will have to elongate the factory bolt holes or get adjustable upper or lower control arms,thank all of for your responce
Old Nov 1, 2015 | 12:39 PM
leadfoot4's Avatar
FWIW, I elongated the bolt holes, but I did it so long ago, I forget how much I did....maybe 5/16".
Old Nov 1, 2015 | 02:20 PM
2MCHPWR's Avatar
i was able to get -1.1 with elongating the slot slightly.
Attached Thumbnails Camber Maxed out-ws6align1_1.jpg   Camber Maxed out-slot.jpg   Camber Maxed out-slot2.jpg
Old Nov 2, 2015 | 03:43 AM
LilJayV10's Avatar
You are 100% correct on that. Good call.
Old Nov 3, 2015 | 04:16 PM
Sam Strano's Avatar
LS1TECH Sponsor
okay, it's negative... how negative is it? Performance cars should have some negative camber anyway. If it's street only then you clearly don't want too much, but you also do not need to be within the ridiculous stock specs either.
__________________
Old Nov 4, 2015 | 06:23 PM
bhotrod3's Avatar
I have negative camber at least one degree or more,wore the inside of the tire anyway thats what they said when i had it aligned,looks like more to me especially on the passenger side,anyone know about how much to slot the factory holes for sure 5/16 seems like a lot,also do i just need to slot the cam bolt hole or are there others as well.....Thanks
Old Nov 4, 2015 | 06:37 PM
Sam Strano's Avatar
LS1TECH Sponsor
That's not exactly specific. What are the specs? Toe will also wear the inside out quickly, as will worn bushings. Slow down and tell me what the alignment sheet said before you go cutting on stuff.
__________________
Old Nov 7, 2015 | 05:59 PM
bhotrod3's Avatar
Ok i got under my car today and looked at the control arm slots,looks like i have plenty of room to move the arm enough for proper alignment,so no slotting needed,apparently ive been using a incompotent alignment shop,with that being said what should i have the alignment set to,my car is a daily driver,about fifty miles a day,i understand there is a better alignment than stock.....thanks
Old Nov 8, 2015 | 07:13 AM
leadfoot4's Avatar
Since you're talking daily driver, my suggestion would be this:
Camber......0*, both sides;
Caster......4.5-5* on the drivers side, and a touch more on the passenger side, to allow for "road crown";
Toe-in.....in digital-speak, .02-.03* per side. In mathematical numbers, about 1/16" total, 1/32" per side.
Old Nov 8, 2015 | 08:21 AM
bhotrod3's Avatar
Thanks for the info....I appreciate all of the feed back
Old Nov 9, 2015 | 01:48 PM
Sam Strano's Avatar
LS1TECH Sponsor
I'm glad you looked. And sorry to have been blunt about this, but it happens a LOT that alignment shops suck and/or people jump to conclusions.
I'd still run a little camber, -.5 for me. But the caster and toe leadfoot 4 stated are what I'd do.
__________________
