Name this part
Old Dec 30, 2015 | 04:33 PM
Defined1983's Avatar
Default Name this part
hey guys what is name of the part in the pic that is above the upper front A arms? The A arms were bolted up to it and i'd like to purchase new ones. Is it the shock mounting bracket? If it is does anyone know where online i can find them to purchase?
Old Dec 31, 2015 | 12:52 AM
joeformula's Avatar
You can try rockauto or just have those powder coated
Old Dec 31, 2015 | 07:38 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
https://ls1tech.com/forums/suspensio...uca-mount.html
Old Dec 31, 2015 | 10:55 AM
klinznilk's Avatar
Have to do what I did.
Actually after being told couldnt without buying entire assembly... i bought a used set second hand dirt cheap off here and then powdercoated
Old Dec 31, 2015 | 04:39 PM
looks awesome. thanks
Old Jan 15, 2016 | 03:34 AM
Have to do what I did. Actually after being told couldnt without buying entire assembly... i bought a used set second hand dirt cheap off here and then powdercoated
your rubber bushings look new, can you tell me where to get those? I looked on rockauto and couldn't find.
Old Jan 15, 2016 | 05:36 AM
klinznilk's Avatar
They just cleaned up. Those are original ones car isn't driven in winter (Iowa here) and only 60ish thousand miles on it.
Old Jan 15, 2016 | 05:40 AM
do you know what that part is actually (the insulators) called and where i can purchase? I took your advice and just got the other part powdercoated in black. thank you
95wannabe's Avatar
Do you mean the rubber isolator on top?
Moog, Strano, NAPA...
http://www.moog-suspension-parts.com/moog-k6573
Old Jan 15, 2016 | 07:11 AM
klinznilk's Avatar
That is NOT the part
And as far as I have been able to find out its not purchaseable and can't even locate part number for it
Old Jan 15, 2016 | 07:15 AM
klinznilk's Avatar
Part on left is what you posted<br/><br/>Part ib right is what he is looking for
Old Jan 15, 2016 | 10:52 AM
95wannabe's Avatar
ah right,.. my mistake
Old Jan 15, 2016 | 03:02 PM
yes sir. need the one part on the right! having no luck at all finding
Old Jan 15, 2016 | 04:12 PM
JimMueller's Avatar
I couldn't find that insulator which goes in the UCA mount either when I rebuilt mine. The parts manual calls the mount a 'front upper control arm support, PN 11515744', which was only available as part of the UCA. They list a bushing used with the UCA, but it's the bushing used with the bolts which hold the UCA to the support.
Old Jan 15, 2016 | 04:45 PM
did you just not use any?
Old Jan 15, 2016 | 04:56 PM
JimMueller's Avatar
I didn't use any. The one which was in it fell out because it was beat to hell and I couldn't get it to stay in. I just put a lot of marine grease in the top of the shock to try to mitigate the shock nut from rusting.
Old Oct 19, 2016 | 06:40 PM
LS1121's Avatar
Did anybody actually find this rubber bushing?
Old Oct 22, 2016 | 04:53 PM
99SSJarhead's Avatar
You could probably find a used set off ebay but otherwise leave it off as some cars didn't have them and no one has been able to find a manufacturer for them. Pack it with marine grease and drill a small hole from the engine bay above it so you can pump more in if necessary and it will be fine with just the bottom isolator
