My Silverado is driving me NUTS!!
I have a 2008 Silverado and its in real good shape.. The only problem with it is I have a front end clunk/clatter when I go over bumps or uneven roads.. Sounds like it's under the floor pan on the driver side.. Idk what it can be but it's driving me insane.. Has anyone out there experienced this with your truck? Help..
Thanks I'll give a look over but I think if it was the ball joints the truck would have came apart by now because it's kinda sounds like something it real loose..
Have you crawled under there and looked? If you have traditional steering, there are tons of joints under there that can clunk (inner tie rod, outer tie rod, pitman arm, idler arm). Mine had 190k on them, and I had lots of shot parts that were like limp noodles. I also had a ball joint where the ball stud moved up and down. After replacing everything with Moog stuff, clunk is gone.
The shaft itself doesn't go bad. It's a collapsible shaft and GM used a compression grease on the splines of the shaft the eliminate the knocking of the two metals. Over time the grease breaks down and the clunk comes back. GM used to offer a service kit for the shaft but I don't think it's available any longer.
