Sway bar end links too tight?
Just installed Strano front hollow sway bar on my 1997 Z28. My car is worlds better handling! Love it! But i am concerned that the end links are too tight. I kind of had to tighten it this much or the end link would have been really loose. So should i back off a bit? Or am i okay?
LS1Tech Premium Sponsor
Everything in picture looks good. When you tighten down the end links you will get a little compressing of the end link bushings.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
LS1TECH Sponsor
I think it's too tight. The bushings are quite squished and poly doesn't really like that. Back them off and start to tighten them again. As you do, just try and spin the spacer tube. When you can't turn it anymore with your fingers, that's tight enough. Stop there.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
THIS is why this man is a 'treasure' on here!
