- Chevrolet Camaro 2010-2015: How to Adjust Parking Brake
Step by step instructions for do-it-yourself repairs
Browse all: Brake Guides
Electric E-brake using line lock
If you go with the Mico, you may want to keep your chocks in the boot for really steep hills, etc.
Or break the lines loose to release the pressure. You'll learn real quick how much is enough. I used to put my truck in neutral and let it roll and apply the brake lock to see how much it needed. Of course you'd need more pressure parked on a hill.
Is the only problem the pedal/handle, or are you also trying to figure out how to apply the brakes? You may want to reach out to the manufacturer of the rear calipers, and see if they have an option for you. I've seen kits where they offer an option for e-brake connections on rear calipers. Again, this should be a mechanical means to stop the car from rolling, and not hydraulic.
There are several other brands available and possibly cheaper but considering the obvious damage if the car rolls away they aren't that expensive.
http://www.ebay.com/itm/2013-CADILLA...xUiJzK&vxp=mtr
Yes the only problem is with the handle. Hooking it up to the caliper is simple. It is the same design as a stock Miata just on Wilwoods.
I also agree that this isn't the safest route to go. It is more for anti theft then being a true parking brake. I rarely will park on a hill and when I do, put it in gear and turn the wheels toward the curb. That way if the brake fails, the curb won't.
Overhead?
Doesn't seem like the ebrake hardware would take up much room. How about building a new mounting system that ties into the cage?
Typed this into Google image search, and got all sorts of ideas, just not sure your limitations.
'custom emergency brake kits'
