Vogtland Lowering Spings....Any feedback?
Does anyone have any feedback on ride quality and stance from the Vogtland springs. I'm going to upgrade my shocks here soon on my 96 Z28 and I might as well replace the springs while I'm at it. I have old DMS springs, which have a good stance (after the rear springs had to but cut) but I think my ride quality has suffered. If anyone could give me some feedback on these it'd be appreciated. I only found a couple pics of F-body's with them installed after a lot of searching.
Thanks
Thanks
If you like the height of the springs keep them and upgrade the shocks, that should drastically change ride quality (especially if they are stock) and see if you like the way it rides then.
And why vogltland springs?
LS1TECH Sponsor
The Vogtland quality is very nice. But the rates are not to my liking which is why when I was having them make my springs, the springs were very, very different in both front and rear rates. In fact I still carry Vogtland springs if you really want a set but I think you can do better with a more specifically developed application like my springs.
If you want to see what they look like it's easy to find a lot of pics. There are threads here about Strano Springs, hell you can Google that and click on "images" and a lot of them come up. I don't give any specific number on the drop because that takes into account the starting height, which can vary a ton due to so many different OEM springs, the fact those springs might be worn, cut, or have been replaced with some other lowering spring already. So to me a picture showing the result is the best answer to what it'll look like.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
