Recipe for a killer 60ft in a turbo f body?
As the title implies, what is the recipe to have a turbo f body 60ft? Preferrably sub 1.4 60ft.
Time and time again it is stated that turbo cars cannot 60ft. While im a big fan of drag racing, I have seen a decent amount of turbo cars 60ft very close to NA/Nitrous cars.
I personally have full suspension(tubular A arms, k member. viking coilovers etc) minus a stock ARB and stock 3.42 gears, th400 w/brake and plan on running 275 Pro radials while weighing 3300# w/me. I also hope to be in the neighborhood 600-700+whp.
I know quality parts makes things easier, but do any turbo guys have any insight on how to get a good 60ft?
My relatives were running a turbo camaro and were cutting mid to high 1.3x's. Albeit they were making over 800 to the wheels on a Mustang dyno. They were running a TH400 with a transbrake, 3.42 gearing, anything higher and it would run out of gear before the quarter. Nothing super crazy suspension wise. Qa1 front SA shocks with Strange SA or DA rears. Non adjustable rear LCA's with relocation brackets, adjustable panhard and short torque arm. Front A arms were stock along with the k member too if I remember correctly, no front sway bar however. Rear drag bar was a necessity on that thing. Subframe connectors and a cage and that thing could LAUNCH.
Biggest thing if I remember was the TH400 and the transbrake. The turbo took a long time to spool up and once it let go, it let go hard
LS1Tech Premium Sponsor
Beyond suspension the single most important part of the combo will be your torque converter. It is the lifeblood of how the power is applied to the ground and can have drastic affects on the way the car performs.
Give us a call or message, we'd be glad to set you up with the rest of the package you need at great prices.
I cut a 1.27 on strange sa up front. stock shocks and springs in the rear. i cut 1.2x a few times. nothing better than 1.27. turbo 4.8. id be lucky if it made 750. short trq arm. trz arb. weighed 3600 with me in it. Races are won in the shop. Even though it is a basic car. i put alot of time into prep before i went racing or testing.
A lot of anti-squat, and tight shock rebound in the rear will let you hit the tires hard and keep it planted. Turbo cars like load, so tight a converter and tall gearing will let you build boost good on the brake and have control over how hard it launches. Also front rebound will be a big factor in controling front end lift. My car had issues finding the back bumper with just strange single adjustables in the front. Didn't have enough rebound control and up it went
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Those are pretty close base line numbers to work with. I would go a little higher on the rear compression though. Usually around 6 or 7. Of course until you get it on the track and see how it reacts it will be tough to really fine tune it in, but that should give you a place to start. My car went 1.27 with a very similar setup to what you have minus the coilovers. So you should be in the same range dialed in
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
