bmr TA012R. Problems
You have to jack up the rear end a little and preload it a bit, then install the shaft. But you can't let the suspension sag after install because the shaft will be hitting the crossmember/loop, and you risk denting the driveshaft and ruining it
So now I either have to cut and re-weld the loop to fine tune it, or get creative when jacking the rear of the car up by not letting it go into full droop mode.
Give bmr a call or pm them here, or wait for them to reply in this thread.
You might be able to space the crossmember down a bit using some plate steel/washers..
You have an adjustable torque arm correct? You can always adjust the pinion angle back to correct for it.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
