Help with UMI Rear suspension and future setup
I have UMI:
My UMI transmission cross member and adjustable torque arm are going to be delivered by Monday. When I lowered my car I didnt know I needed the relocation brackets. So I had terrible wheel hop. So I ordered the relocation brackets. I immediately put the control arms in the lowest hole and went to town, not knowing to take a pinion angle measurement.
So I have been driving like this for awhile and it did get ride of the wheel hop. However my rear end is whining and I get a NASTY vibration at 120+.
So with the new torque arm and relocation cross member coming in, I will be measuring for the pinion angle as i bought new hardware and the magnetic angle finder.
I have a couple of questions:
- control arms
- control arm relocation brackets
- Adjustable Panhard bar
- Can I mesure the angle with the car on level jack stands and jack the pumpkin up to the same position as if it was on the ground by mesuring wheel gap?
- Will the proper adjustment of the pinion angle correct the high speed vibration?
- What hole in the relocation brackets should I baseline with when I start to adjust the torque arm?
- Should I replavce my Universal joint because of all this?
Good morning.
Yes, you should be able to set everything properly with the axle at standard ride height. We are trying to avoid having the rear hanging down in full rebound.
If you think you hurt a u-joint it's cheap insurance to replace sooner than later.
Having the driveline within the proper angles should cure your vibration problem.
With the advent of iPhones and cool apps, I've been using the Tremec toolbox with good success. It calculates for you. The Spicer Tool Kit also works nicely.
ramey
ramey
Good morning.
ramey
ramey
In your opinion do you think the whining from the rear will be cured too? Vibration should be gone as you stated. I am excited to get this setup because it is one of the last stock pieces left and I am excited to actually be able to hook up.
How will the car behave differently than before?
I don't think that's a mix-up. Our tubulars work fine for standard road racing. We make boxed for those wanting add'l strength but I'd say we sell 5 tubular sets for every boxed for road racing.
If the whining is due to pinion angle then it should go away. If there is something wrong with the Ring N Pinion then it won't help. Our Mustang GT whines from the factory. Sounds like a blower. Ugh.
Car behave differently with pinion angle change? Probably won't be too noticeable other than the smoothness.
