Noise from ground contol rear-right perch.
Does anyone have trouble with their ground control rear spring perch moving around and make noise? Its fine most of the time, except when going into steep or uneven driveways. When I jack the car and pull the wheel, the perch ins't sitting properly, but when I use a jack to raise it back to normal level it sits fine. I'm sure it because of the angle the spring is at when the suspension is high, is there anything I can do to keep the perch still?
