Front spring rate question
I have them adjusted more then half way and it still sits too low for me. Does this mean the springs are to light to raise the car or can I keep adjusting the jam nut to raise it up?
DA Strange shocks S5071
Thanks!
So if I keep compressing the spring it will raise the car higher?? I was worried that the spring was too weak to raise the car while compressing..
Far as the ride it is a 100% track car. I can get the tires off the ground a good 3-4"s. Will #275 or #300 springs get the tires up higher?
The front spring rate has little to do with it. the idea is that the longer softer springs (note longer not shorter softer springs) push up on the body when you hit the gas. The car pulling tires is more to do with rear grip and power and geometry. Though I'll point out here that if you watch serious cars like ProStock cars they don't pull the wheels way up because you can actually hurt your times, and the way up in the air catches a lot of air.. and that takes power to push through.
If I can't get to the height I want I will look into different springs. I'm only looking to go another 1 1/2- 2" higher.
This year has been alot of trial and error but it's getting there.
Thanks!
