Why Lower?
Old Nov 26, 2016 | 01:46 PM
LS1121's Avatar
Talking Why Lower?
My question is why does "the average Joe" lower his car? When I look at my car I see a large gap between the top of the tire and the bottom of the fender well and I would like that to be less, however this is the way the car was designed. There are only 2 solutions to my quest. #1 is change the spring so the tire sits higher in the opening or #2 fill up more of the opening with Tire.
Option #1 requires a lot of work because you get into "physics", like making the spring do the same amount of work in half the space, then alignments in the geometry of the entire drive train of the vehicle again a lot of work and $$$$$.
I put one of the 19" wheels from my corvette on my Z28 and it looked terrible, kinda like one of those 1985 Monte Carlo's driving around with 22" wheels where the wheels are worth more than the car. I understand that lowering any car is good for certain types of racing but I do not race my Z28 (much) . So back to my question why do most people lower their car? Since I went back to (MOOG) rubber bushings and installed Koni Str.t struts I do not feel much of a loss in handling compared to Monroe struts and Poly bushings. I'm thinking about different sways but that is another topic for another thread. Is it appearance that most are looking for? If the larger wheel/tire combination is the best answer for me then is there anything that I am missing?
Old Nov 26, 2016 | 02:12 PM
AnotherWs6's Avatar
Appearance and performance. IMO the car rides and handles better than stock with my setup. Looks good and changed how the car feelsto drive in general. Win win in my book. The only downside is ground clearance. Unless you like the somewhat floaty, cushy stock suspension lowering is one of the best things you can do to these cars.
Old Nov 26, 2016 | 06:34 PM
LS1121's Avatar
my corvette scrapes every time I go over a speed bump at stock height and that's what worries me about lowering the Z, the scraping makes me crazy. The Y pipe is flat on our cars to begin with due to ground clearance.
Old Nov 26, 2016 | 07:20 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Lowering by itself won't do nearly as much as a good shock upgrade - even at stock ride height. I've been in several 4th gens with stock springs that had fantastic handling and ride quality with just a shock or shock & sway bar upgrade.
The appearance aspect is all subjective. I personally dislike the slammed look, especially on Trans Ams as the tire becomes noticeably off-centered within the wheel well (the ground effects make this more noticeable), and would rather have stock height than that. But a slight drop can certainly look nice.
Old Nov 26, 2016 | 07:32 PM
JD_AMG's Avatar
I agree with what RPM WS6 said above about the shock/spring difference.
Im guessing you put lowering springs and shock on at the same time?
I did everything separate, one at a time. The loose, floaty feeling you got when stock was 100% the shocks, not the springs. Koni sports on stock springs feels amazing, super glued to the road (zero float), BMW like ride and composure. You tell the car what to do and it does it effortlessly and with actual grace (compered to the bull in china shop feel on stock shocks). The performance difference you felt when putting both the shocks and springs on at the same time was 80% the shocks, 20% the springs IMO, yes the yellows make THAT much of a difference, they certainly did for me.
Lowering takes some of that good ride quality away, but improves handling obviously (with proper lowering springs).
Old Nov 26, 2016 | 07:33 PM
JD_AMG's Avatar
This is a compromise you have to deal with when lowering a car or driving a low car in general. You have to figure out if its worth it to you for the look to have possible scraping issues.
Old Nov 27, 2016 | 08:48 AM
01Z0H6's Avatar
Used to be an old beer commercial... "Why ask Why"..
For me, I like the look of the "slightly" lowered 4th gen fbod... BMR springs and some Bilsteins along w other supporting mods makes for an aesthetically pleasing look, and a far better ride. But, maybe that's just me.
Old Nov 27, 2016 | 09:00 AM
LS1121's Avatar
Ok so how much would it cost me to get "the look"? I already have Koni Str.t shocks, and how much ground clearance do you have?
Old Nov 27, 2016 | 09:49 AM
JD_AMG's Avatar
You need to buy lowering springs or cut your stock springs, then get the front end aligned, thats it.
May also need an adjustable PHB to recenter the rear end, but thats up to you.
Old Nov 27, 2016 | 10:49 AM
30thanniv's Avatar
I lowered mine for two reasons in this order:
1-Looks
2-Handling
Went with Strano's. It is not slammed. Looks just right.
Old Nov 27, 2016 | 11:07 AM
SoFla01SSLookinstok's Avatar
I also hate scraping & that's why I'm still at stock ride height. From your OP, about bigger wheels/tires, it will take up some of the gap between the fender but it will also raise the vehicle higher off the ground.
Old Nov 27, 2016 | 12:54 PM
RixTrix's Avatar
Stance is everything.....
Old Nov 27, 2016 | 01:16 PM
Darth Cypher's Avatar
I'm not a fan of lowering at all. But I changed my shocks and springs at the same time. I wanted aftermarket springs for better handling and I choose a setup that lowered the least (from what I've read). I went with Strano springs. The car sits lower and I have gotten used to it. I actually like the look better now versus the 4x4 look of the stock springs. I don't like slammed but a slight, tasteful drop is not bad.
Of course, now the car sits level as it had a slight rearward rake. I might do the heater hose mod on the Strano springs to bring up the back a little bit. I still have the stock rear isolators but would like that slight rake look again. I just haven't gotten around to it yet.
Old Nov 27, 2016 | 04:52 PM
JimMueller's Avatar
I didn't lower mine for looks, it was only for performance; I don't care for a huge uneven gap going around the circumference of the tire in the wheel well. Mine's built for street/AX/HPDE so it's corner balanced; I think my frame LCA bolts are about 6.5" high in front and 7" high in the rear. The lowest part of the chassis is the ARH intermediate exhaust pipe, which is about 3" from the ground. I do have flat spots on the collectors from when the car was lower in the past, but when I had the Koni's rebuilt I raised the height a little to extend the life of the collectors..
Old Nov 27, 2016 | 04:55 PM
01Z0H6's Avatar
Exactly what he said....
Old Dec 8, 2016 | 08:21 AM
Major Shart's Avatar
To me "slightly" is key. I have a T/A for the strip but I just got an SS to semi daily and just drive around and enjoy. I want to set the car up to be a great driver and look good doing it. I look at my new Camaro and I think it looks low already. But sometimes I see the wheel well gap and want to lower it some. Not slam it, never that. Then I don't want issues dragging my exhaust all over either. I'm a little torn actually. I'm running the 35th anniversary wheels on the car.
Long story short my BMR springs will be here today. I'm not in a hurry to install them because the car does look fairly low and because of the weather. That being said those of you with experience with the BMRs, are you slammed or is it tastefully lowered?
Old Dec 11, 2016 | 08:02 PM
01Z0H6's Avatar
I picked up some Sam Strano's today.. Can't wait for them to arrive...
