Bilstein step by step installation
Old Dec 26, 2016 | 01:13 AM
SarGntoperez's Avatar
Default Bilstein step by step installation
I need some info for the slp bilstein installation, does anyone have a step by step on how to install the bilstein shocks for a 2002 trans am? The front i onw the come with a washer, nut, and a cap. The rears i think 2 nuts, bushings and washers
Old Dec 27, 2016 | 09:19 PM
Stew2000's Avatar
http://www.ls1howto.com
Old Feb 25, 2017 | 09:52 AM
Default Bilstein
Originally Posted by Stew2000
bilstein front struts comes with a metal cap a washer and a nut, do you know where the washer goes?
Old Feb 25, 2017 | 07:39 PM
Stew2000's Avatar
Man its been a few months since i did mine but I believe it goes under the nut.
Old Feb 25, 2017 | 08:15 PM
Default Bilstein
I blieve so but wasnt sure, i believe the metal cap goes on the strut and the nut all the way in the top when everything is assembled , i think the washer goes in the shaft like in the middle where the upper strut mout sits, what do you think
Old Feb 26, 2017 | 10:47 PM
Cpt.Derrek's Avatar
here's my old setup when I sold it fully assembled. Maybe that'll help
Old Feb 26, 2017 | 11:07 PM
Default Bilstein
Nice thanks, It looks like the washer goes under the nut, did you reused your dust boot from the decarbon shocks?
Old Feb 26, 2017 | 11:19 PM
RevGTO's Avatar
Pontiacerator
I'm having a hard time remembering if it's for Bilsteins or Koni's, but is the washer big and thick and about an inch in diameter? If so, it goes on the shaft under the upper mount.
Old Feb 26, 2017 | 11:25 PM
Default Bilstein
Ok so the thick washer goes on the shaft where the upper mount sits correct? And the other metal cap sits in the body correct?
Old Feb 26, 2017 | 11:40 PM
Cpt.Derrek's Avatar
yes reused the dust covers, I don't know which thick washer you're talking about, or the other metal cap? sorry its been a while since I assembled those. I swapped out with the UMI coil over setup
Old Feb 26, 2017 | 11:46 PM
RevGTO's Avatar
Pontiacerator
That's what I'm recalling. You can't just have the upper mount sitting on top of the shock. You pound the metal cap on the top of the shock - I know that for sure. And then if I remember correctly, the big washer sits on that. I don't think a washer goes under the nut inside the upper mount.
Old Feb 26, 2017 | 11:48 PM
Ok yeah i think thats how it goes then thanks alot for the help
Old Feb 26, 2017 | 11:53 PM
RevGTO's Avatar
Pontiacerator
I think I'm probably confusing you more than helping. I've installed several sets of Bilsteins and Konis, but it's been awhile and I think I'm mixing them up. If you could post up a picture of the washer, that would help.
I seem to recall using the dust covers from DeCarbons on the new Bilsteins. They have a built-in washer on top so I'm not sure you'd need another washer on top of those. But if it's supplied that's where it has to go.
Old Feb 27, 2017 | 12:01 AM
https://www.google.com/search?q=camaro+bilstein+struts&sa=X&biw=320&bih=4 40&site=webhp&tbs=vw:l,ss:44&tbm=shop&prmd=sivn&sr pd=8577371511222426587&prds=epd:936070850792268728 ,cdl:1,cid:3687177744153714761&ved=0ahUKEwj39rHizK _SAhXmzVQKHTTaAtsQgTYInAQ
Old Feb 27, 2017 | 12:11 AM
Cpt.Derrek's Avatar
ok so this is what you should have. those big metal caps get pounded onto the tops of the shocks as covers after you swap the spring perch. then the washer and nut go on the very top like in my picture above.
Old Feb 27, 2017 | 12:21 AM
Ok and also do i need the bump stop? I heard the decarbon dust boot comes with a bumpstop underneath
Old Feb 27, 2017 | 12:25 AM
Cpt.Derrek's Avatar
I don't recall a bump stop. If there was one there stock I would go ahead and transfer it. Basically your replacing everything with what was supplied, anything not included you reuse.
Old Feb 27, 2017 | 12:28 AM
Ok cool thanks bud
