How to tell if car is lowered
I'm 99% sure the TA I bought is lowered. Is there any measurement that I could take with different wheels and tires on the car that I could compare to stock ride height? Waiting for this weekend to get the car on my father in laws lift to do a visual on the springs, but if that fails I'm going to be left trying to figure out for sure if it's lowered. Unfortunately the different wheels and tires I understand makes it hard to compare to stock so I didn't know if there was some kind of measurement I could take on the shock itself to compare. Any bright ideas?
I'd start by seeing what color the springs are, and if you can see any tags (GM) or other markings on them.
And one way that might tell you quickly is a look at the LCA angles, assuming no brackets.
__________________
Got the car on the lift and saw Eibach logos on the rear springs. The front was a little trickier since the Eibach logo was facing the rear. Had to get a little peaker mirror and spend a few minutes trying to get a good angle. Didn't find anything matching the numbers I pulled off the springs but I'm assuming if they're Eibach then they're definitely lowering springs.
That's correct. Red or black? At least we can figure out roughly how much lower you are than stock, but you are definitely dropped, as Eibach doesn't do non-lowering springs.
__________________
So either one of the 4 Pro-kits (stupid there are that many, shows ignorance of this platform) or maybe a set of the SLP version. But some sort of lowering spring that won't have you absolutely decked.
__________________
