rough ride
Old Jun 24, 2004 | 08:38 PM
bluebomb's Avatar
Default rough ride
I lowered car with eibach pro kit and car bottoms out and give a bad ride, Please help with shock info and a panhard rod. Do I need adjustible or not, are they easy to adjust, first time lowering vehicle, all help would be appreciated.
Old Jun 24, 2004 | 09:47 PM
John95Z28's Avatar
First, are you using the factory shocks? If you are, I'd suggest Konis if they're in your budget, or Bilstein would be a good choice as well for less $$.
As for the panhard question - I would first check to see if your left/right alignment is off. Park the car on a level surface, and use a plumb bob or something similar (heavy weight at the end of a string) and a ruler to measure the horizontal distance from the outside edge of your rear fender to the edge of your wheel's rim. Then measure the same distance on the other rear wheel, and compare the two measurements. If the difference is very small or zero, then there's no need for you to buy an adjustable panhard rod.
Old Jun 24, 2004 | 09:59 PM
2_wacko's Avatar
Like John95Z28 said it might be the shock's. If you have the stock shock's on put Bilstein's. Do you have the rubber isolater's in the rear this might be another problem.
