poor handling at speed
Old May 17, 2004 | 07:31 AM
todds87ss's Avatar
Default poor handling at speed
Long time listener, first time caller...
I was wondering if anyone else has a problem with high speed (>125) stability? Car seems to bounce back and forth violently. Also it does not "squat" at speed like other high performance cars I've had in the past. The only suspension mods the car currently has are homemade SFCs and strut tower brace (the problem existed before their fabrication). Also, the factory panhard bar seems to have an unnatural bend downward at the upper connection. Is it supposed to be straight?
Thanks in advance,
Todd
Old May 17, 2004 | 09:20 AM
mitchntx's Avatar
Welcome ...
The PHB is uspposed to be straight, yes. Check tire tracking to make sure you aren't "crabbing" the car while it's traveling in a straight line.
Your username implies you have an '87 year model car. Is that the case or is it a 4th gen?
Old May 17, 2004 | 11:45 AM
todds87ss's Avatar
Thanks for the quick reply, I'll check the track. The sig is an old holdover from a Monte Carlo SS I recently parted with. Old habits...
My current ride is an 01 Z28 M6.
Todd
Old May 17, 2004 | 12:46 PM
mitchntx's Avatar
I don't have sigs turned on. Some folks go a little overboard on "look at me" stuff and just clutters things up.
Have you had the car aligned? To stock or the recommended custom settings of -1.0* camber, +4.5* caster and zero toe?
Old May 17, 2004 | 12:57 PM
jimmyblue's Avatar
Moderator
The stock suspension is pretty high and there's not
much "ground effect" going on - possibly its negative.
Lowering might improve things somewhat. Of course
there are other "ground effects" like speedbumps
and armadillos....
Old May 17, 2004 | 01:00 PM
todds87ss's Avatar
I have had no such alignment, but have had good wear on tires. I'll have to look for a good alignment shop...I've had no luck finding one locally.
Thanks again,
Todd
Old May 17, 2004 | 01:18 PM
trackbird's Avatar
You said upper attachment point on the PHB. Are you looking at the upper PHB brace or the actual PHB (the lower is straight and runs from the frame to the axle, the upper is between the frame and the frame and has a kink to clear the exhaust).
Old May 17, 2004 | 04:42 PM
todds87ss's Avatar
Yes, the upper mount to the PHB. So the kink is supposed to be there...Thanks for the info
Old May 17, 2004 | 06:54 PM
trackbird's Avatar
Yup the kink belongs in the top bar, the bottom one should be straight.
I'm going to have to send Mitch back to school again......I think that's 2 mistakes in a week
Mitch, is hell month finally over?
Old May 17, 2004 | 10:38 PM
John95Z28's Avatar
Trackbird, you are a wise sage among F-body owners. Your posts are both true and noble, and you saved me from buying cross-drilled rotors.
Old Jun 24, 2004 | 07:04 PM
todds87ss's Avatar
Default finally fixed
Well, it's finally fixed. I lowered the car (cut the coils) 1 coil in the back and 1 1/4 coil in the front. Not a dramatic change, but enough to drop the front lower than the back. I also boxed the rear LCAs and the factory panhard bar. Thanks for all the help.
Todd
Old Jun 24, 2004 | 07:56 PM
trackbird's Avatar
I'm glad I could help. I keep trying, but so few listen. I guess those advertising dollars really do work.....
Old Jun 24, 2004 | 09:23 PM
John95Z28's Avatar
Yep, adverstising works on us fer sher. Have you seen Fight Club? There's a line something like "we work jobs we hate to buy **** we don't need"
Old Jun 24, 2004 | 10:04 PM
mitchntx's Avatar
Looks like it ... UPPER PHB, huh? All I read was PHB ... Oh Well ...
Way to keep me in check
Old Jun 25, 2004 | 12:03 AM
trackbird's Avatar
Between the 2 of us, proof reading for each other, we almost make one pretty good mechanic....
