how do you remove caliper??
Old Jun 26, 2004 | 01:49 AM
TSAEB's Avatar
Default how do u remove caliper??
I want to remove my caliper completely off...i now the caliper itself is only holded down by two bolts...i cant get the bottom bolt cus this other attachment (dont know what it is...look like a springwith three whires going to it....a friend said it had to do with the atilock)on it...can someone explain to me how to take it off...thank you...and how do i keep the brake line (if thats what u call it) from bleeding all the brake fluid when i disconnect it from the caliper do i just put a plug through it??? thanks
Old Jun 26, 2004 | 11:18 AM
IllusionalTA's Avatar
What kind of car? The three wires are probably the abs sensor its a clip.. should be albe to just unclip it.. As far as the caliper goes.. SHould be albe to get the 2 bolt's easily..
Old Jun 26, 2004 | 11:22 PM
TSAEB's Avatar
93 camaro m6
Old Jun 29, 2004 | 01:05 AM
TSAEB's Avatar
it was the parking brake...sorry i didnt know what it was...i just left it alone.
