Suspension Question
You could raise the ride height in the rear with coil springs or a coil-over setup.You could also shim the rear springs but I would question how sagged out the current springs are with the issue your having with 15's.
For the A-Body platform we offer Factory height springs along with 1" and 2" lowering.
With a coil-over set-up you would be able to adjust the ride height from approx. factory height to 3" lower and anywhere in between.
If you need any info feel free to give me a call here at the shop, I have pictures I can send you of customers cars with our springs installed so you can get an idea of what the different springs will do for the stance of your car.
Craig
