Panhard relocation on a lowered car?
In trying to find out if I can get true duals, I have seen that I will need to get a panhard relocation kit, which is no big deal. On the other hand, don't you need an adjustable PHB for lowered cars? Mine is lowered 1.5" if I am to believe the previous owner. Will a plain PHB relocation work, or do I need something more robust?
The relocation kit replaces the top panhard bar support completely and has a step/curve in it to make room for dual over the axle pipes. So yes, you throw the stock stamped piece of garbage in the trash and replace it completely with the panhard relocation kit. Everyone suggests using an adjustable panhard bar but you can get away with a non adjustable. In my case, I bought a Founders non adjustable panhard bar and am about to order the relocation kit from them as well so I can run a single 4" exhaust up and over the rear end.
LS1Tech Premium Sponsor
Yes, you need an adjustable panhard bar for a lowered car, and it is recommended for use with the relocation kit as well. When you combine the 2 together, it is very highly recommended
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
