rear end or not?
rear end or not?
Knocking/bouncing noise from the rear? 98 ws6 trans-am, knocking/bouncing only turning left and under load ( getting on it) have not heard any grinding from axel, these are things been done to it,...motor changed to 2000 corvette ( blew up org) trailing arms, pan hard rod, sway bar, poly bushing on all, high-performance brakes, weld in subframe connectors, stage 3 spec clutch, etc pinion bearing change out one time, did have a twin-turbo on it , has since been taking off long time before problem showed up , car has 93000 miles on body, thanks in advance
