rear suspension tips
Old May 22, 2017 | 09:43 PM
Hypforlife32's Avatar
Default rear suspension tips
whats up guys, i went to the track a few weeks ago and im not totally up to speed on tuning suspension. I have Qa1 single adjustable rear shocks. Mid west chassis 9 inch, there anti roll bar and a BMR 160lb rear spring. The shocks are 4-5 clicks away from soft. the control are is in the middle of the 5 settings on the control arm brackets and also the front part of the tq arm is in the middle notch, -2 degree pinion angle...does anyone have any suggestion on settings? This is leaving at 3300rpm on the t brake. I can go more but first time out using the brake as you can see i let off then got back into it...didnt mean too.
pass was 10.20 at 138mph. 11.5 psi. 1.57 60 ft.
File Type: mov
Old May 23, 2017 | 08:55 AM
MidwestChassis2's Avatar
Better pass would work and you are always welcome to email midwestchassis@hotmail.com if you ever need advice.
Old May 23, 2017 | 09:21 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
To me the rear didn't look bad. No squat or separation. Very composed. The front though looked a little soft. I would go up on rebound in the front and slow the front end coming up. It looks like it came up to fast and bobbled some. Try that and hit it again and let us see what it does
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old May 23, 2017 | 03:26 PM
The front is a single adjustable and it is all the way stiff already...
Old May 23, 2017 | 04:49 PM
BMR Sales2's Avatar
What brand shocks? What springs do you have on the front?
__________________
Glenn ***
Sales Tech
813.986.9302
Old May 23, 2017 | 04:52 PM
qa1 front struts, and 300lb spring. i do have an iron block and t6 turbo up front with your guys k member.
