Rack and Pinion hydraulic lines
1998 with the FE2 suspension option.
I have a leaking line on the rack and pinion. I was hoping to just replace the line instead of pulling the whole steering unit out. I can't seem to find any part numbers for just the hard lines that go across the rack and pinion. Not the lines that go to the power steering pump. Am I outta luck and will just have to replace the whole unit?
If I had the fitting sizes for those I could probably just make my own lines. Maybe I am just not searching on the right terms/words.
Thanks,
Dan
Thanks,
Dan
