rear Flynbye C5/C6 upgrade on F-body. What ebrake cables?
Has anyone done the rear brake conversion using Flynbye's (C5/C6) kit?
Instead of using the f-body rear e-brake setup on the axle side, it uses a corvette. I am trying to determine where to get cables from or if there is a universal cable I can use for measurement and then have permanent cables made.
Yes I've used the search on this forum, nothing turned up.
Thanks for any help.
Yeah and he doesn't answer any emails I send either. I´m planning on using the very same bracket on my Iroc. Already have the calipers and rotors from a c6 z51.
So did you find out anything about the cables?
