Front End Torques Specs Needed
It had these suspension mods put on last year. It may have about 1K mi on them now.
BMR 98-02' F-body A-arm Kit (AA001, AA002)- HAMMERTONE
BMR Control Arm Hardware Kit, Front Upper And Lower
BMR Adjustable Panhard Bar w/polyurethane ends - HAMMERTONE
Strano Performance Lowering Springs
Koni STR.T Shocks
SLP Weld-in Subframe Connectors
Can anyone tell me what the torque specs are for the ball joints, sway bars, A arms, etc..
I checked the BMR site and their installation instructions give no torque specs.
Id like to go thru everything to make sure nothing has worked itself loose.
Thanks!
Stabilizer Shaft Insulator Clamp Bolt/Stud
55 N·m
41 lb ft
Stabilizer Shaft Upper Nut and Bushing
23 N·m
17 lb ft
Lower Control Arm Mounting Nut (Assuming stock hardware, 95 ft lbs if using upgraded)
100 N·m
74 lb ft
Lower Control Arm Nut
110 N·m
81 lb ft
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
torque numbers are in lb-ft lower ball joint nut 81 upper ball joint nut 39 ^^ important: never loosen ball joint nut in order to align cotter pin, you may over torque nut up to 1/6 of a turn to align cotter pin. inner tie rod nut 35 brake master nut 21 lower control arm mounting nut 74 outer tie rod end nut 35 shock absorber lower bolt 48 shock absorber lower nut 48 shock abs upper mount bolt 37 shock abs upper mount nut 32 stabilizer shaft insulator clamp bolt/stud 41 stab. shaft upper nut & bushing 17 upper control arm nut 39 wheel bearing hub bolt 63 caster +4.3° to +5.3° preferred = +4.8° cross caster -0.7° to +0.7° preferred = 0.0° camber -0.1° to +0.9° preferred = +0.4° cross camber -0.7° to +0.7° preferred = 0.0° sum toe -0.2° to +0.2° preferred = 0.0° rear sum toe -0.3° to +0.3° preferred = 0.0° rear thrust angle -0.25° to +0.25° preferred = 0.0° Trim height specs suspension F41: tire size 235-55, D = 118mm (4.6") Z = 30mm (1.2") suspension FE2: tire size 235-55 D = 118mm (4.6") Z = 31mm (1.2") suspension FE2: tire size 245-50 D = 125mm (4.9") Z = 37mm (1.5")
