Suspension set up
Weld rts 71
Mickey thompson 315/35/17 rear drag radials
Mickey thompson 275/40/17 front tires
Moser fab 9
Moser torque arm
Moser cross member
Moser double adjustable lca's
Moser double adjustable pan hard bar
Bmr drive shaft saftey loop
Bmr 2 pt subfram connectors (i have 3 pt sub fram connectors not installed)
Bmr xtreme rear sway bar.
Pst 3.5 drive shaft
I am staying with stock shocks and springs for now. When I do the front suspension I will be switching to coil overs. Hopefully this happens over the winter.
My question is what do I set the pinon angle at? Do I measure from the torque arm or the drive shaft. Where should I set the lcas at in the lca mounts? Any help would greatly be appreciated.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
