Braking Problem and Recommendations!
If you have stock brakes, the sleeves in the caliper brackets will flat spot over time and also cause binding. At some point, those caliper brackets also need replacement to keep the pins sliding freely.
To rule out the abs, deactivate it by either pulling fuse, or pulling a connector from one of ur sensors and ziptie it up. Then drive and see if it does the same thing. If not, abs related
