How to ensure no wheel hop at drag strip???
I know that wheel hop is a killer. It has been many years since I've run anything at the track. My car -M6- is basically stock power wise. I have BMR Springs, Koni shocks, Founders adjustable LCA's, LCA relo brackets and running NT05R's. Before I did any suspension work and on normal street tires I would frequently get nasty hop on the street. While that's gone away I'd like to know if what I have is sufficient to ward off wheel hop when running at the track. I've heard of people breaking rearends on the 1-2 shift as well as the launch.
What's the difference in losing traction on the street with street tires vs losing it on a track with drag radials? I recall thinking how slippery the track felt while running at Englishtown years ago in another car on street tires. I spun but no hop. I'm basically a newb to track driving for all intents and purposes
I really have no desire to do anymore suspension modding right now.
FYI - I currently have the stock 30K clutch in the car and it will slip sometimes. I'm wondering if this is will help. I also have a Monster 3 for the car which is obviously not gonna slip.
LCAs' tie the rear end to the subframe(along with the panhard bar and torque arm). Adjustable LCAs' allow for moving(centering) the wheels/tires in the wheelwells. The angle of the LCAs' is what matters and that's what the LCA relos are for.
Original OEM LCAs' have rubber bushings and allow for quite a bit of movement(comfortable ride) which doesn't help traction and wheel hop.
If you feel the car hopping then jump off the gas quick and try another approach.
LS1Tech Premium Sponsor
From what you have described, I doubt you will have any issues with it. Your parts list covers most of the parts needed to reduce wheel hop. If you experience any still, the next step would be to relocate the torque arm off of the transmission
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
If the LCAs control movement front to rear I suppose the torque arm is controlling pinion angle ??
one of the questions I'm also asking is how does the track differ from the street? Are cas more or less prone to issues with DRs on a track vs the street?
