Koni STR.T Shocks
Unfortunately my budget doesn't include the better Koni sport but I've read that the str.t are comparable to bilsteins possibly, anyone using stock springs with the Koni strts?
You can use Koni yellows with stock springs as well and get an unbelievable difference in handling, ride, feel and stability. Then later down the road if you choose to lower you already have the best "off the shelf" shock to do it.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Im at work so i found the photobof the shock and parts it came with... im assuming this just slides down and is tapped on top of the shock regardless of lowered or not... too late now anyways haha.
The nut on the end for the strut mount, is there a torque spec on it? I'd hate to decompress the spring and it have too much for it to b handle. Couldn't get a socket to tighten because the rod kept turning, I put vice grips on the end with a wrench on the nut and turned the rod the opposite way to tighten it till I couldn't by hand anymore. By the way... it's a PITA wor king with springs, especially when you realize your compressors are one ring too short of enough clearance for the strut to be mounted
The nut is a pita to tighten but apparently you can get a clunk if it's not tightened well enough. I just snugged mine up as tight as I could.
Car drives like a dream, can definitely feel a difference on curves, there's minimal body roll, if any. I'll be swapping the rear shocks and sway bar next week.
For the strut mount nut, it was too rusted, all the pb blaster in the world would get it. When I installed the new ones, I had the neighbor just put an impact wrench on them. He mounted the springs on for me as well, best 20.00 dollar's spent instead the 195.00 he wanted for installing everything
Thanks again for the information/support
